【已解决】部署访问异常
21.5k
Fatal error: Composer detected issues in your platform: Your Composer dependencies require a PHP version ">= 8.2.0". You are running 7.3.4. in D:\phpstudy_pro\WWW\tigshop\vendor\composer\platform_check.php on line 24
评论7
你是windows系统吗?如果是请问你是怎么安装swoole的?
composer显示已经安装了啊
Warning: require(D:\phpstudy_pro\WWW\tigshop\vendor\composer/../thans/tp-jwt-auth/src/helper.php): Failed to open stream: No such file or directory in D:\phpstudy_pro\WWW\tigshop\vendor\composer\autoload_real.php on line 71
Fatal error: Uncaught Error: Failed opening required 'D:\phpstudy_pro\WWW\tigshop\vendor\composer/../thans/tp-jwt-auth/src/helper.php' (include_path='.;C:\php\pear') in D:\phpstudy_pro\WWW\tigshop\vendor\composer\autoload_real.php:71 Stack trace: #0 D:\phpstudy_pro\WWW\tigshop\vendor\composer\autoload_real.php(61): composerRequire95074356954881db626e20fc4c240ca4('cc25fa796cd7d29...', 'D:\\phpstudy_pro...') #1 D:\phpstudy_pro\WWW\tigshop\vendor\autoload.php(7): ComposerAutoloaderInit95074356954881db626e20fc4c240ca4::getLoader() #2 D:\phpstudy_pro\WWW\tigshop\public\index.php(22): require('D:\\phpstudy_pro...') #3 {main} thrown in D:\phpstudy_pro\WWW\tigshop\vendor\composer\autoload_real.php on line 71
我调整版本后现在报这个错误
根据提示您还没有完成composer安装插件库
查看全部7条评论
58
