【问题反馈】执行composer install报错
31.3k
PHP Fatal error: Uncaught Error: Call to undefined function Composer\XdebugHandler\putenv() in phar:///www/server/php/82/bin/composer/vendor/composer/xdebug-handler/src/Process.php:98
Stack trace:
#0 phar:///www/server/php/82/bin/composer/vendor/composer/xdebug-handler/src/Status.php(59): Composer\XdebugHandler\Process::setEnv()
#1 phar:///www/server/php/82/bin/composer/vendor/composer/xdebug-handler/src/XdebugHandler.php(101): Composer\XdebugHandler\Status->__construct()
#2 phar:///www/server/php/82/bin/composer/bin/composer(28): Composer\XdebugHandler\XdebugHandler->__construct()
#3 /www/server/php/82/bin/composer(29): require('...')
#4 {main}
thrown in phar:///www/server/php/82/bin/composer/vendor/composer/xdebug-handler/src/Process.php on line 98
Stack trace:
#4 {main}
评论5
您好,这个是因为put_env 函数被禁用了导致的,如果您是宝塔安装,可以去对应php版本中将 putenv() 禁用函数删除,然后再尝试一下。
前面搞定了,现在500错误,开启DEBUG,请问这个是要改数据库链接还是什么意思呢?
环境变量搞定,这一步没有效果。Too few arguments to function think\\Request::filterData(), 4 passed in /www/wwwroot/m.chuxi128.com/app/Request.php on line 154 and exactly 5 expected
查看全部4条评论
65
