在Spring Boot 3中整合Spring Security与JWT
18.7k
1. 添加依赖
在你的pom.xml中添加Spring Security和JWT的依赖:
<dependency>
    <groupId>org.springframework.boot</groupId>
    <artifactId>spring-boot-starter-security</artifactId>
</dependency>
<dependency>
    <groupId>io.jsonwebtoken</groupId>
    <artifactId>jjwt</artifactId>
    <version>0.9.1</version> <!-- 确保使用适合的版本 -->
</dependency>
2. 创建JWT工具类
创建一个工具类用于生成和解析JWT:
import io.jsonwebtoken.Claims;
import io.jsonwebtoken.Jwts;
import io.jsonwebtoken.SignatureAlgorithm;
import org.springframework.stereotype.Component;
import java.util.Date;
import java.util.HashMap;
import java.util.Map;
@Component
public class JwtUtil {
    private final String SECRET_KEY = "your_secret_key"; // 请使用安全的密钥
    private final long EXPIRATION_TIME = 1000 * 60 * 60; // 1小时
    public String generateToken(String username) {
        Map<String, Object> claims = new HashMap<>();
        return createToken(claims, username);
    private String createToken(Map<String, Object> claims, String subject) {
        return Jwts.builder()
                .setClaims(claims)
                .setSubject(subject)
                .setIssuedAt(new Date(System.currentTimeMillis()))
                .setExpiration(new Date(System.currentTimeMillis() + EXPIRATION_TIME))
                .signWith(SignatureAlgorithm.HS256, SECRET_KEY)
                .compact();
    public Boolean validateToken(String token, String username) {
        final String extractedUsername = extractUsername(token);
        return (extractedUsername.equals(username) && !isTokenExpired(token));
    private String extractUsername(String token) {
        return extractAllClaims(token).getSubject();
    private Claims extractAllClaims(String token) {
        return Jwts.parser().setSigningKey(SECRET_KEY).parseClaimsJws(token).getBody();
    private Boolean isTokenExpired(String token) {
        return extractAllClaims(token).getExpiration().before(new Date());
3. 创建过滤器
创建一个JWT过滤器,用于在每个请求中验证JWT:
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.security.authentication.UsernamePasswordAuthenticationToken;
import org.springframework.security.core.context.SecurityContextHolder;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.web.filter.OncePerRequestFilter;
import javax.servlet.FilterChain;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.io.IOException;
public class JwtRequestFilter extends OncePerRequestFilter {
    private JwtUtil jwtUtil;
    private UserDetailsService userDetailsService;
    protected void doFilterInternal(HttpServletRequest request, HttpServletResponse response, FilterChain chain)
            throws ServletException, IOException {
        final String authorizationHeader = request.getHeader("Authorization");
        String username = null;
        String jwt = null;
        if (authorizationHeader != null && authorizationHeader.startsWith("Bearer ")) {
            jwt = authorizationHeader.substring(7);
            username = jwtUtil.extractUsername(jwt);
        if (username != null && SecurityContextHolder.getContext().getAuthentication() == null) {
            UserDetails userDetails = userDetailsService.loadUserByUsername(username);
            if (jwtUtil.validateToken(jwt, userDetails.getUsername())) {
                UsernamePasswordAuthenticationToken authToken =
                        new UsernamePasswordAuthenticationToken(userDetails, null, userDetails.getAuthorities());
                SecurityContextHolder.getContext().setAuthentication(authToken);
        chain.doFilter(request, response);
4. 配置安全策略
在安全配置类中配置JWT过滤器和其他安全设置:
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.EnableWebSecurity;
import org.springframework.security.config.annotation.web.configuration.WebSecurityConfigurerAdapter;
import org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter;
@Configuration
@EnableWebSecurity
public class SecurityConfig {
    private JwtRequestFilter jwtRequestFilter;
    protected void configure(HttpSecurity http) throws Exception {
        http.csrf().disable()
            .authorizeHttpRequests()
            .antMatchers("/authenticate").permitAll() // 公开认证接口
            .anyRequest().authenticated()
            .and()
            .addFilterBefore(jwtRequestFilter, UsernamePasswordAuthenticationFilter.class);
5. 创建认证接口
创建一个控制器用于处理用户认证并生成JWT:
import org.springframework.security.authentication.AuthenticationManager;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.web.bind.annotation.*;
@RestController
public class AuthController {
    private AuthenticationManager authenticationManager;
    @PostMapping("/authenticate")
    public String authenticate(@RequestParam String username, @RequestParam String password) throws Exception {
        authenticationManager.authenticate(new UsernamePasswordAuthenticationToken(username, password));
        final UserDetails userDetails = userDetailsService.loadUserByUsername(username);
        return jwtUtil.generateToken(userDetails.getUsername());
6. 测试
启动应用程序。
发送POST请求到 /authenticate,提供用户名和密码以获取JWT。
使用获取到的JWT进行后续请求,将其添加到请求头中:
Authorization: Bearer <your_jwt_token>
